Error code P171900?
I did a check with my obdeleven and got one single error code.
details below:
08 Air Conditioning
    System description: AC Automat
    Software number: 3V0907044FK
    Software version: 4901
    Hardware number: 3V0907044FK
    Hardware version: H34
    Serial number: 00000B01783820
    ODX name: EV_ACClimaPrehVW37X
    ODX version: 002030
    Long coding: 12110004002110011005000000101036
    Trouble codes:
        P171900 - Function restriction by engine control module
            Intermittent
                Date: 2021-01-25 15:21:55
                Mileage: 97 km
                Priority: 6
                Malfunction frequency counter: 1
                Unlearning counter: 51
                Dynamic environmental data: 02869027C1FB
anyone knew what the issue is?
thanks
Many thanks
Unless you get an error on the dash too or some other weird behaviour don't worry too much. OBDEleven will occasionally show "faults" that are not real, but rahter a temporary status of the module that sends out a false alarm.
Ah,mthanks.
ive cleared the fault code.
It just hasn’t connected properly to the module. Mine sometimes throws up a central locking motor fault in each door. There’s no fault, it just doesn’t connect to the module properly to be able to run a scan so returns a fault code.
