Alloys
Hi,
Does anyone know if 2016 Origami 17” alloys will fit the 2010 Yeti? Offset at ET45 is correct but unsure of PCD (both 5 stud) or any other issues.
Thanks in advance.
Origami a OEM fitment from Skoda
Pretty much anything VAG that is 112x5 will fit, I have Altea alloys on my 2010 Yeti
Alloy wheel ORIGAMI 17" for YETI
7,0Jx17 ET45
5L0071497K FL8 Glossy black
https://eshop.skoda-auto.cz/en_CZ/alloy-wheel-origami-17-for-yeti/p/5L0071497K+FL8
7,0Jx17 ET45
5L0071497L 8Z8 Silver
https://eshop.skoda-auto.cz/en_CZ/alloy-wheel-origami-17-for-yeti/p/5L0071497L+8Z8
7,0Jx17 ET45
5L0071497Q FL8 Metallic black
https://eshop.skoda-auto.cz/en_CZ/alloy-wheel-origami-17-for-yeti/p/5L0071497Q+FL8
Since 2011, the Audi A6 has used 5/112 66.5 rims.
The Yeti uses a 57.1mm centre bore with it's 5/112, so 5/112 66.5 wouldn't fit as the rim wouldn't be centred on the hub.
There are probably other examples, so always check that the rims are 5/112 57.1 not just 5/112.
Edited by Carlston
Dont forget if the centre bore is too big, but everything else is sized correctly you can get spigot reducing rings to reduce the bore back to 57.1mm required for the Yeti. ....
Usually less than £10 per set from most alloy wheel dealers.
Hope it helps :)
