No RS Theme on Virtual Cockpit
As mentioned elsewhere I've recently retrofitted a virtual cockpit, all coded up and working with maps.
I've tried to activate the RS theme with no success. Using both the obdeleven app and setting the adaption manually (tube and display depiction set to version 3).
Anyone any clue (from searching I'm definitely aiming this towards @SashaGrace)
So u want to do this on a non-RS Superb........
The SportLine has the RS theme as well. What is the full part number? Do you have the speedo end set to 160 or 180 mph?
Speedo end (called tachometer end value in obdeleven??) was set to version 0 (260kmph) but I just changed it to version 2 (280kmph)
Oh hang on its just updated to RS theme. I changed to 280kmph set the obdeleven app to classic theme then to RS and it worked!
I changed mine to see if the red needles helped, but I still find it not the best dash to be able to read with just a quick glance. A small individual point at each speed point would be a simple addition and a great help.
