Smartlink
I remove the protection compenent but I lose smartlink+ now I see : this function has not been enabled please contact your dealer
And I lose instaled function enabling codes in SwaP what is the solution please
Visit your local Skoda dealer... but I really doubt they will be able o help you if your car was installed wih unit taht was not supporting these features.
Before removed the protection components I have the MirrorLink and carplay and Android auto but now when I removed the protection I lose it
The unit supports these features. They disappeared when I removed the component protection in my country dealer with 60 euro
Smartlink cannot be activated. we tried to solve it. BCM does not support it before 2019, he would also have to replace the BCM
But it was on, when I removed the component protection, I was asked to contact the dealer
Like @pab567 told you if your car did not have it earlier, is mainly impossible to have it activated afterwards, your car does not support the SWaP codes for it. Look also what @wirer said he has an extensive experience to Fabias.
Maybe the easiest way is to contact Pab about your unit.
@RABAH has SWING, I cannot help with SWING.
Oh sorry, I misread, thought that he got a Bolero or Amundsen. Then @RABAH you need to investigate if the method of wirer is suitable for you, sorry.
My car supported 4 swap code 00060300 and 3 other I believe that there are a solution
