2009 Fabia 1.4 petrol, Instrument Cluster is pulsing and all warning lights flashing
I have taken the cluster to a good firm in Waterlooville hants called Cartronix who have tried but can not fix it and suggest I replace with either new or second hand. They told me if i buy second hand i need to make sure the Parts are the same for ref " 5J0920 941B" and then get it recoded, any one know where i can buy a cluster ? or any suggestion to get mine fixed.
thanks in advance
if a specialist cannot fix it...............dont see any other way other than to replace, unless offcourse your not confident in the companies ability ??
one here
https://www.ebay.co.uk/itm/SKODA-FABIA-1-2-BBM-INSTRUMENT-CLUSTER-CLOCKS-5J0920901B-2009/143632350195?hash=item217127bbf3:g:C30AAOSwhiVe54pT
and here
https://www.ebay.co.uk/itm/SKODA-5J-1-2-1-4-16V-MANUAL-INSTRUMENT-CLUSTER-SPEEDO-DIALS-CLOCKS-5J0920911B/143850375049?fits=Model%3AFabia|Cars+Year%3A2009&hash=item217e268789:g:OFoAAOSwE0NftVJA
Also was the vehicle plugged in to diagnostics as the dash panel does have the ability to store / log faults to be read
Edited by UrbanPanzer
No error code present, Thanks for the link to ebay ads Im told the part number must be exactly  the same is this true ?
thanks in advance
its always best to be the same...........unless you can be sure the ones with a diff letter suffix are a superceeded version, but its best to check with a dealer in that instance.
PS those I linked are the same.
EDIT..........if there are no error codes, maybe its a power supply issue.........if your handy with a soldering iron maybe worth taking apart and "reflowing" those connections at the power plug.
Thanks, just to clarify my Part number of 5J0920 941B   the " 941B " is not that important ?
kind regards Andy
Those second hand clusters are a really good price! :) I would be tempted to have a punt at that money. In the word of cars, <£25 is pennies really.
  • Sponsor
Crucially important, I would think.
Have you looked into what is involved in making a secondhand cluster work in a different car? My vague feeling is that it's not particularly straightforward.
Edited by Wino
