Eibach Springs & Tracking
I recently fitted my Eibach springs :D and goodyear f1 gsd3's.... canny :cool:
But, I took the car in for tracking and they advised they needed different settings from skodas standard settings now it is 25mm lower :confused: They could use skodas settings but this would not be correct for the new lower springs :eek:
Has anyone else come across this and where can I get the settings I need to set the tracking so it is correct for the new springs or did you stick to the standard settings :confused:
Something around standard should be ok.
We are only dropping 25mm and not 60. A larger drop would probably require more adjustment to try and counter some of the extra camber gained.
When i spoke to jabba sport about my tracking he said normally theres not much difference, and no need to alter. Iam lowering using eibach springs and dampers though.
Toe will remain the same, camber and castor you cant adjust anyway.
Still advise doing 4wa when the suspension has been off though.
Thanks all.... I was going to get the tracking done the other day when I had my F1 gsd3's fitted but the guy said to check first ..... Ta
