Both rear fogs
Anyone know the procedure to activate both rear fogs on a 2007 rs?
I can't seem to find it on vag com
You can't do using VCDS , it needs dealers ODIS.
I know this is a MK2 Octavia section, but you can definately active up the second fog light via VCDS on a MK3 - no hassles.
There was a problem with the FL IIRC.
Actually a 2007 model isn't a FL so............
Anyway, I had a non FL & a FL and it was only possible to activate on one of them.
