Gear K.nob
Does anyone know if the Fabia geark.nob is a standard VAG fitting and if any VAG geark.nob would fit? I've seen some nice Audi ones. :)
Any manual one should fit on just fine.
I don't suppose the gaiter is a standard fitting too? Probably too much to ask for that too. :D
Thanks for the info. :)
The gaiter should be, however the frame may not be. But you can seperate these and use your frame if needs be.
Thanks for the help. :)
Audis reverse is in a different place
Depends which gearbox it has.
true
