Rear damper setup
Seem my rear shocks are on the way out.
Is there any way to say what kind of shocks I have?
2.0TDI MY15 CR150 4X4 COMBI
ECP gives me with "electronic suspension control" but what is this? Self-levelling, DCC or something else?
They cost several times as much as regular shocks, and I don't know if I need them.
search for DCC cancellation kit
or install cheaper with better performance
-> Bilstein B6 DampTronic
Do you have DCC?
If you don't then use normal dampers ;)
If you do, as MartiniB mentioned above, you'll either need:
- a DCC delete to use regular dampers
- replacement OEM dampers
- aftermarket DCC dampers like the Damptronic
No, I don't have DCC.
So there's no specific self leveling shocks needed then. Thanks.
