Windshield wiper motor problem
Hi all, read and watch a lot for wiper issues but didnt find the right answer. After i strip  everything out found that power isn't going to the motor. Strange ting is when i take the key out there is power, switch it on - no power. Something cut the power, so i am wandering what that can be. And is it safe to take power directly from the fuse wich work ok and conectet with the motor directly (one new cable)
Thanks for any help in advance 🙏😉
Other than disconnecting the battery negative for a minute to see if it unscrambles things I can't think of anything that would cause the symptoms you describe.
Bear in mind the front wipers are inhibited if the bonnet is open, you may want to check its latch switch.
Yes the bonnet, that is for another topic but just a quick one, i see people closing bonnet properly and using the wee space. Note... There is a pin on the front wich locked the bonet and it stays open and voala 😊😉
You're talking turkey and I've no idea what you mean.
