Better Windshield washer?
My nozzles does not spray wery well. Three skoda repairshops tells me thst they Are as they should be...
Does Any one know some nozzle thqt will spray better and wider and fit the citigo?
Edited by aerik
I assume you have cleaned the nozzles with very fine needle?
Yes. And the repairshop have also tid to clean and adjust.
OK. I have no idea what may fit without a bit of fettling.
My washers are fine, but have VW changed them over different model years perhaps?
I dont know. Mine is the facelifted model. And there have never been sprinkler fluid on the lower outside if the drivers side.
Maybe a weak pump or kinked or clogged plastic tube?
Well. Why would three skoda repairshops tell me its ok then. after all, they would be able to make money fixing it. it is not a warranty case.
I've no idea - garages are mostly useless....
What's actually wrong with it?  Can you give a better description or some pictures as that might help others help you...
