Front light adjusted for driving on the right hand side - PLEASE help!!
Guys - please help me out here and stop me from going crazy, I'm desperate!
I could have sworn that my 2017 Kodiaq Edition was able to physically turn and lower the front lights automatically when you went into settings and set the light to 'driving on the right hand side' or 'driving on the left hand side'.
I could sworn I actually saw the beam lower and turn to the side slightly when I did that.
Now it's been in for a repair and swap out of the rear fog light from one side to the other as we have moved from UK to Europe, and since then, it has failed it's local MOT-equivalent because the front lights are not pointing in the right direction.
When I go into that setting and change it, all that happens is a slight colour change (and maybe a slightly dimmer beam). But from memory when driving over the channel and changing it, the light actually turned slightly.
The garage tells me all that happens is a slightly dimmer beam, no actual movement. If I want to, (I have no choice, to be able to pass the MOT) they can get the lights completely swapped out for a EU version which points in the right direction. But I really feel like they have screwed up somewthing in the electrics when they swapped over the rear fog light.
Am I wrong?
Thanks in advance,
At least in my experience, the following is true for VAG cars.
- If the car has halogen headlights, there is sometimes a lever that will convert from the ECE cutoff with a flick up to a completely flat cutoff.
- If the car has LED/Xenon headlights, they normally drop slightly and move over. The cutoff doesn't change.
I'm not familiar with the Kodiaq but I imagine you fall into the second category and I'd be very surprised if it could change from RHD ECE to LHD ECE cutoff patterns...
I think you're gonna need new headlights I'm afraid :(
It's the Edition trim, which came with LED lights, SKODA Kodiaq Edition Specification | Pulman ŠKODA (pulmanskoda.co.uk)
But based on what you are saying, that won't help me in any case for the long term and I still have to get them changed? Thank you :)
