ABS and brake wear wire.
i have destroyd my wire to the abs and brake wear and i need a new one but cant find any to my car? left driver side skoda octavia RS 2006.  the ones i found only have abs contact. or can i find only the contacts and fix it myself. is there any part number on the wire loom that i can find? any help is and im thankfull.
I found exactly the same. All parts places even after looking at my VIN said the loom only had the ABS wire.
I went on the parts diagrams and found the one that was actually fitted to the car -  Both ABS and brake wear connector.
1k0927903ac
I found a parts Cataloge online and found this number 1K0927903J, whats the diffrence ? J and ac?
I can't see it being much different. Mine was repaired using a lead pair off a scrap Audi TT. Worst case, the support grommets won't be in the right on place, but a bit of rubber hose and a couple of cable ties will fix that.
Edited by StevesTruck
1K0927903J is for cars with xenon headlights, as it has the additional  connector for the level sensor
tack så mycket, much appreciated :)
