Coasting
On 18/06/2021 at 04:50, eksa said:
I didn't like this coasting function in normal mode. It is good to have this functionality in Eco mode when you select it,   but it not good that you cannot disable it even on Normal mode..   How can coasting be called "normal" way of driving??
I think engine braking is something that is necessary which gives the driver more control and comfort without touching the breakes everytime..
Same thing with ACT.. it would be good to have it for Eco mode but why is it a part of normal mode??  Why do i have to drive in the most economical way all the time? I just want 4 cyl to be ready all the time without a switching operation which takes some miliseconds which i will definitely feel.
We will replace our company cars this year, my first choice would be superb again but learning that there are these new functions which cannnot be disabled, I will look for other options which doesn't limit you between Sports mode and "Most Economic Mode Possible"
ACT is not noticeable in driving the only time I notice it when it the dash changes and I look to see what come up. Totally seemless
Edited by pragmatix
  • Replies 50
  • Views 12.1k
  • I like the coasting mode, yes, it keeps the engine ticking over, but there is no deceleration caused by the ‘engine braking’, so the car will go further when off the throttle.  This means for instance
  • Does it not re- engage drive when you touch the brakes and provide engine braking as in previous versions.
  • Coasting function can be disabled (turned off).  And when functioning and you want off then touch the accelerator, or a wee tap of the brake, or maybe drop a gear to decelerator.   Best saying what en
