Dash Trim Replacement
Hi,
Does anybody if you can remove the cloth trim that fills the gap between the top of the steering column & dashboard? Mine has a nice fag burn in it from the previous owner & I'd like to replace it if possible.
Cheers!
I think it's
6Y0 857 565 68F covering black
Thanks Stu,
I'll get one ordered.
Yes, pull the trim towards you and it will clip out.
The cloth is just stuck on with some sort of double sided tape to the underside of the top of the steering column housing and therefore will be easy to remove.
Cheers guys
03 Fabia 1.9 Tdi Elegance - bog standard with:
Numerous stone chips, couple of dents, scratched dashboard, broken central air vent, flaky Skoda badge on boot, paint flaking off on edge of boot :eek:
Last time I buy second hand!
