Octavia 1.4TSI service intervals
Hello!
I've just bought a 2018 1.4 TSI DSG Octavia estate for my wife.
I've been searching high and low for a table or document stating the service intervals for it but i can't find anything.
I've got a Leon Cupra and everything is clearly and easily available regarding the servicing of it (DSG oil change intervals, Diff oil change etc)
Obviously it will get the oil and filter every year and brake fluid every two but what about DSG oil, does it need a cambelt?
Sorry if this has already been covered. I had a search but nothing of use came up.
Welcome to the forum.
The DSG & Diff is different from with your SEAT.
The first brake fluid change is at 3 years, or get the H20 level checked and maybe do not get the fluid changed if no need.
It is each 2 years after the first change.  Maybe have it tested each year, or changed if you want whenever.
The DQ200 7 speed DSG you have needs no Oil Change, now or ever.  (But maybe ever is too long, maybe in another 5 years if you have the car then.)
Diff oil to be left alone alone like the DSG.
Cam belts are a whole other discussion and there are plenty threads on that for the 1.4TSI.
Edited by e-Roottoot
Perfect. Thanks
