Octavia MkIII brake disc and pads required
Good afternoon,
I hope all are well?
I've tried to search for the correct size brake discs and pads front and rear for my Octavia estate but it keeps throwing up several options.
Is anyone aware of the standard sizes and possibly part codes for Euro Car Parts?
Any help appreciated
The Octavia MK3 has four different diameter front brake discs.
276mm, 288mm, 312mm, 340mm.
Build code 1ZF = 276mm
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/615/subcategory/615010/part_id/2547315/lang/e
Build code 1ZE = 288mm
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/615/subcategory/615020/part_id/2550123/lang/e
Build code 1ZA or 1ZB = 312mm
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/615/subcategory/615025/part_id/2550123/lang/e
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/615/subcategory/615030/part_id/2550123/lang/e
Build code 1LG = 340mm
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/615/subcategory/615040/part_id/2561338/lang/e
It's easy enough to measure the diameter of the front brake discs with a wheel off.
I suspect the Greenline has either 276mm or 288mm diameter front brake discs.
The Octavia MK3 appears to have three different diameter rear brake discs.
253mm, 272mm, 310mm.
Build code 1KD matches 253mm, build code 1KS and 1KT matches 272mm, and build code 1KW matches 310mm.
Edited by Carlston
Thanks for the help. Took the wheel of and seems to be 288 and 253. All ordered but annoyed it appears I don't have brake wear sensors  yet can only find front pads with integrated sensors
*off
The 288mm and 253mm brakes are both TRW.
OEM part number for the front brake pads is 8V0698151
OEM part number for the rear brake pads is 5Q0698451A
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2016/drive_standart/753/hg_ug/615/subcategory/615060/part_id/2550123/lang/e
These OEM numbers can help with finding suitable aftermarket replacements.
Glad I found this post, some great info here, thanks Carlston! :thumbup:
I have exactly the same question regarding my '13 Octavia 2.0tsi VRs -
I'm looking for front pads & discs. I've roughly measured across the front disc diameter with a tape measure (wheel still on) & it appears to be around 330mm so I guess it must be the 340's I need, I can't find that build code that you listed though, there's loads of 3 digit codes on the boot floor sticker but none of them are 1LG though, am I looking in the right place?
Not all the build codes are on the boot sticker.
All Octavia MK3 2.0TSI RS cars have 340mm diameter front brake discs.
Octavia MK3 2.0TSI RS Front Brake Pads 8V0698151C
10 8V0698151C 1 set: brake pads with wear indicator for disc brake 340X30MM
Octavia MK3 2.0TSI RS Front Brake Discs 1K0615301AD
12 1K0615301AD brake disc (vented) 340X30MM 5X112
I would go for EBC DPX2127 brake pads with the 340mm diameter front brakes
https://www.ebay.co.uk/itm/263099668139?epid=249579955&hash=item3d41f656ab%3Ag%3AJKwAAOSwvZZZcaBd&LH_ItemCondition=3
If you don't know much about EBC brake pads, there's a youtube video that takes a tour of the factory. They are a British success story.
Jonny Smith from The Late Brake Show Takes a Tour of EBC Brakes’ HQ
https://www.youtube.com/watch?v=JeB76-_Etig
Edited by Carlston
Thank you so much Carlston, that's really helpful! :thumbup:
