Rns310 entertainment system
Hello , anyone know how to change the dash board into miles an hour from km?
also getting the speedo larger in the centre.
I tried holding down bottom right button for a few minutes but didn’t get the extra section needed
if you have a maxidot dash, then you need to login with a diagnostic tool and set the vehicle to "ROW" rest of world setting and turn "OFF" Alt speed display, you will then have a large digi display in the dash to select.
Great thanks, I need a smaller adapter to its small dongle whole.
ke ?
Not sure this will help. I go to Skoda maybe
I dont know what "tool" that is, but I doubt it will do what you need, you ideally want VCDS or Skoda to do it, not even sure "if" a dealer would change the world spec of a vehicle or not.
You can get Carista or OBD 11, if you intend to stick with VAG cars get VCDS.
Carista or ODB11 bother let you change this function.
Edited by Mickmartin
 The dongle you have plugs into the socket in the fusebox above your right knee. The socket in the other photo is a USB,
