Octavia Estate Etec SE Windows When Locked
Anyone know if it’s possible to set the car to pull up all windows when you lock the door. I’ve left the passenger front window wide open twice now when I’ve left the car.
On previous models it was possible to do this by a prolonged press on the lock button.
Hi, it´s the same on Octavia IV, keyfob long press on close to close all windows or long press on unlock to open all windows.
I guess the OP is wanting the windows to close upon locking the car. Yeah holding the button closes them but you need to remember they are open in the first place. Which is entirely the issue here.
Well its not a biggie to lock your car with a long press. According to the manual there seems that it is no "function" to set to close windows when locking, but If you have kessy you kan hold a finger against the sensor on driver door. If you do not have kessy you can turn of ignition, open driver door and lift the window button for the driver window. It will then close all windows.
Probably, you will can change that with vcds
