Brake change. Kit required?
I am getting close to needing new brakes all round. If possible, I will do it myself but what kit do I need to do the rear (electric parking brake)?  Any specific tools also?
Yes, for the electric handbrake you need a diagnostic computer capable of winding it back.
You will need some kind of device to put the rear callipers  in service mode ,a Carister or obd 11 should do it and is probably the cheapest way to go
Any idea where to source this?
Is it a case of measuring the disks that are on there already or is there some where I can look up the disk diameters?
eBay is a good start ,you will need the Carista pro subscription but it’s not that much
Yes, high chances there someone is nearby you and will be happy to help
So will I have to change my rear disks/pads on their drive!? Is that how it works?
Where about are you based
Bromsgrove, Worcs.
4 minutes ago, the_worrier said:
Bromsgrove, Worcs.
When you thinking of doing you brakes I’m south Birmingham so could pop over and help if you have all the parts would need to look in my diary if you can give me some idea of when
just write PM to some nearby owner of VCP;VCDS;OBDEleven;Carista and talk . . .
Just over £200 inc VAT for Brembo disks and pads front and rear. Nice.
