Rear axle compatibility - 2008 Ibiza Cupra 5L ?
Hi all,
I need to replace my rear axle on my Skoda Fabia 2011 1.2 TSI (CBZ).
There's an opportunity to get the rear axle of a 2008 Ibiza Cupra 5L for dirt cheap.
Is it a direct fit to my Fabia?
Would really appreciate the help!
Same car underneath so it should fit. I learned from here that our cars have the older rear suspension from the mk1 fabia, while the ibizas and the polos of the same age as our cars had a newer, slightly wider setup. Apparantly both fit straight up. Are you changing to discs?
Thanks for the info.
Already have discs on mine
im wondering why you need to replace it ??
Guessing either rust or it got bent because someone jacked from the middle of it.
Previous owner had talent, no idea how but I have a 1 degree difference on the left side
1 degree difference in alignment?
There are shims you can use to adjust the rear wheels alignment.
