12V socket in boot
I have just bought a Scala but it doesn't come with boot socket fitted now (only available as part of a pack)
1 Does anyone know if the supply wire is hidden behind the trim (have removed blank plate but nothing
directly behind).
2 How does the carpet trim come off  are the edges just tucked under the plastic trim.
directly behind).
Wire's there but no plug
Thanks just need to get carpet off side now
@Osc Could you please share the steps of your modification with some pictures? Thank you.
Unfortunately I haven't managed to pull the carpet off yet to get to the wiring loom.
I can see the loom through the gap behind the  socket blanking plate
so I may try and 'hook ' the loose wires to test them .The  'loose' wires look  brown
coloured anyone know if they are the correct ones?
I have had another look at this and the brown cables I can see are the earth cables attached to body.
I removed the net holding bracket and  bag hanger but still cant pull carpet back. It looks like plastic trim needs to be removed
but that's something I don't want to pull on as I don't want to break anything.
You have to take the plastic trim off not the carpet
Think I will leave it as the chances of breaking the trim clips are quite high as  I don't
know how to unclip them
