2002 Fabia TDi ATD, pings up ABS/flashing warning/triangle+circle lights with daughter driving - Dad !
So scanned car and showed
00290- ABS wheel sensor,
00597 - impulses deviation,
17664 - g62 engine coolant sensor,
P1256 - intermittant,
Checked fuse box top of battery all OK,  checked control plug on alternator, checked 2 joints under starter motor, All OK so ordered a replacement sensor for rear nearside ABS, now the water temp sensor on right hand side near battery,without actually pulling it out does anybody know the part number and a cheap place to buy one ? Cheers Stuart
  • Sponsor
All mk1 Fabias use the same engine coolant temperature sensor, part number  06A 919 501A.
Have you checked for broken wiring, or dirty contacts in the loom connector?
Non-genuine can be had very cheap, but have mixed reviews.
(Claimed) Genuine one here including o-ring and clip for just over £20 which seems good value, especially if it isn't 'fake genuine'.  RRP from Skoda considerably more.
GENUINE VW AUDI SEAT SKODA GENUINE 2 PIN WATER COOLANT TEMP. SENSOR 06A919501A 714819415398 | eBay
Edited by Wino
Hi Wino, thanks for the reply with the number, I've seen one of your replys about the 2 joints underneath and found ours was under the starter motor,both connectors looked fine so I've ordered a wheel sensor after removing the disc and pads and cleaning ring and sensor, and after clearing DTCs it came on again ! Is the water temp sensor just for the indicator dial on the dash display or does the ECU use the info ? Cheers Stuart
  • Sponsor
The temperature sensor is read by the engine ECU, which then forwards the data by CAN messages to any other modules which care; the instrument cluster, obviously, but probably others.
Does the gauge sit solidly at 90/vertical once the engine is up to full operating temperature?
Must admit I didn't notice when I drove it yesterday it's only because vcds flagged it up a couple of times, just ordered one so will wait for the postman. thanks for your help one again. Where do you get the part numbers from ?
