SKODA Octavia Mk2 (Indian version of LAURA type 2) not starting
Dear All - i have SKODA OCTAVIA MK2 2010 model. I am from India, i had flat battery and recharged and cooked up to the car and started for running at idle. it was running fine and all ok. i went away from the car and in some time i heard a rough idle from the car and hearing the radiator kicking off to rotate with huge sound and the car stopped.
i checked the battery, its fine, the fuel pressure and flow is fine at both inlet side and at the HPP side. i have not checked the compression yet, however the car is not starting at all. its crank well but not starting.
the radiator is keeps running when ever i switch on the ignition but not started the car. i checked the coolant temperature seasons G62 and on radiator line and its good.
my next check is to check the thermostat and the speed sensor, compression.
is there anyother check i need to do to narrow down the issue? please help. no engine module error in VCDS.
thanks in advance
Below is my scan data for engine module
Sunday,08,August,2021,19:02:17:29955
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: TMBBNC1Z9AA151374   License Plate:
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBNC1Z9AA151374   Mileage: 116440km-72352miles
01-Engine -- Status: OK 0000
Address 01: Engine (J623-CLCA)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 EJ    HW: 03L 906 018 BR
   Component: R4 2.0l TDI   H20 9977
   Revision: 42H20---    Serial number:
   Coding: 00110012040500080000
   Shop #: WSC 10259 663 00000
   ASAM Dataset: EV_ECM20TDI01103L906018EJ 003008
   ROD: EV_ECM20TDI01103L906018EJ.rod
   VCID: 76B5E25848406D8BA5F-8022
No fault code found.
Readiness: 0 0 0 0 0
Oil level.
ECU fuses (both in car and the battery fuses).
Dear Ken - thanks for your response. let me check that tomorrow and confirm. the fuses in the engine comportment were already checked with test light and all ok. but i have not checked near to the driver seat under the dashboard. can you please help me the fuse number for ECU? i have not checked the relay on the fuse tray in the engine comportment.
also if the fuse to the ECU is blown, will the VCDS able to collect the logs that i pasted above?
oil level is within the limit and good. just before the high mark and it was replaced just few mile before.
thanks
Disconnect the battery negative lead.
Turn ignition on and switch on lights/hazard/horn to drain residual charge.
Switch everything off but leave ignition on.
Reconnect battery negative, switch ignition off then retry.
thanks Mic, and will try and update shortly. great suggestion from all of you and great knowledge.
thanks
Dear All  - i did checked the compression of the cylinder and it clocks 21 bar in all four cylinders. glow plugs are good, the fuses are good in engine comportment. oil level is good. below is my full auto scan from vcds. the car is still not starting. the air filter is clean, the fuel pump is clocking .5 pressure and flow is also good. i have not checked the injector yet. is there anything expert advice to check please help. the car is not starting yet and cranking well.
www.Ross-Tech.com
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 1010
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0104
   Revision: 00H35001
   Coding: 0017665
   Shop #: WSC 33361 790 00000
   VCID: 7BA3F36C7FE230E3DA1-802E
1 Fault Found:
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000001002
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 03538B8C0B924823921-8056
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 4E180AB8B00508C04008008011000124410000AE422085605C0440000000
   VCID: 323D1E48E42831AB497-8066
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 28011  22  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 230110 05  54  0402
   Coding: 0730ED
14 Faults Found:
00153 - Windshield Wiper Motor;  Driver Side (V216)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 116447 km
                    Time Indication: 0
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.00 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01493 - Bulb for Blinkers; Front Left (M5)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 116447 km
                    Time Indication: 0
                    Date: 2015.12.30
                    Time: 00:38:25
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 1
                    Fault Frequency: 69
                    Reset counter: 156
                    Mileage: 116445 km
                    Time Indication: 0
                    Date: 2015.11.02
                    Time: 01:51:37
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
02394 - Parking Light Left Front (M1)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 69
                    Reset counter: 156
                    Mileage: 116445 km
                    Time Indication: 0
                    Date: 2015.11.02
                    Time: 01:51:38
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
02395 - Parking Light Front Right (M3)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 69
                    Reset counter: 156
                    Mileage: 116445 km
                    Time Indication: 0
                    Date: 2015.11.02
                    Time: 01:51:38
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 61
                    Reset counter: 156
                    Mileage: 116445 km
                    Time Indication: 0
                    Date: 2015.11.02
                    Time: 01:51:38
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01495 - Bulb for High-Beams; Left (M30)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 61
                    Reset counter: 156
                    Mileage: 116445 km
                    Time Indication: 0
                    Date: 2015.11.02
                    Time: 01:51:38
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01499 - Bulb for High-Beams; Right (M32)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 54
                    Reset counter: 156
                    Mileage: 116445 km
                    Time Indication: 0
                    Date: 2015.11.02
                    Time: 01:51:40
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01496 - Bulb for Fog-Lamps; Left (L22)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 50
                    Reset counter: 156
                    Mileage: 116445 km
                    Time Indication: 0
                    Date: 2015.11.02
                    Time: 01:51:41
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01500 - Bulb for Fog-Lamps; Right (L23)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 50
                    Reset counter: 156
                    Mileage: 116445 km
                    Time Indication: 0
                    Date: 2015.11.02
                    Time: 01:51:41
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01331 - Door Control Module; Driver Side (J386)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 116446 km
                    Time Indication: 0
                    Date: 2015.11.09
                    Time: 17:43:18
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.00 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01334 - Door Control Module; Rear Right (J389)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 116446 km
                    Time Indication: 0
                    Date: 2015.11.09
                    Time: 17:43:18
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.00 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00907 - Intervention load Management
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 196
                    Mileage: 116447 km
                    Time Indication: 0
                    Date: 2015.12.28
                    Time: 00:55:23
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.55 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01497 - Bulb for Blinkers; Front Right (M7)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 156
                    Mileage: 116447 km
                    Time Indication: 0
                    Date: 2015.12.30
                    Time: 00:38:25
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475 B    HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0006
   Revision: --------    Serial number: 66641000904029
   Coding: 100001
   VCID: 40D944805A84933BCF3-8014
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 07 AIRBAG VW52  025 2400
   Revision: 06025000    Serial number: 0037TR06BB8G
   Coding: 0012343
   VCID: 7DA7FD7461F63ED3E45-8028
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0000003
   VCID: 025D8E881808412B997-8056
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 1Z0 920 803 G    HW: 1Z0 920 803 G
   Component: KOMBI         H06 0305
   Serial number: 00000000000000
   Coding: 110800
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 38292C6002D4DBFB773-806C
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K101270083
   Coding: E9A07F06000202001303
   VCID: 698FB924057EB27338D-803C
3 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 116446 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 116446 km
                    Time Indication: 0
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 116447 km
                    Time Indication: 0
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H06 0305
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6A8DC6280CF8B96B317-803E
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2114
   Coding: 0004854
   VCID: 76B5E25844C06D8BA5F-8022
4 Faults Found:
00120 - Outside Warning Light/Door exit Light Driver Side
00109 - Left Mirror Turn Signal Lamp (L131)
00131 - Outside Door Handle Illumination/mirror Light Driver Side
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 68     3001
   Revision: 00H17000
   VCID: 313F1144ED2E0AB330D-8064
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
            000 - - - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    Battery Volts: 12.1 V
                        PD
                    Temperature: 34.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 0
                        SteerAng n.Init
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0004854
   VCID: 48C95CA07EB4AB7B073-801C
6 Faults Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
00110 - Right Mirror Turn Signal Lamp (L132)
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
   Component: SWING         009 0065
   Revision: 0I001001    Serial number: SKZ1Z2K8364845
   Coding: 0D0004000001
   VCID: 313F1144E12E0AB330D-8064
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 33361 790 1012544
   VCID: 323D1E48E82831AB497-8066
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33331B4C173238A3421-8066
1 Fault Found:
02071 - Local Databus
End----(Elapsed Time: 01:01, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Perhaps the immobiliser is active, can you try removing the air intake pipe and spray a small amount of EZ-START/WD-40 or similar into it to see if it will offer?
I don't think anything mechanical is bad but doing the above test will at least show if mechanicals are okay.
If there was an electrical problem with the injectors like a broken ground wire affecting all of them I would expect that to show up on a scan, I'm still thinking immobiliser due to battery change.
If you've tried everything just fully disconnect the battery and leave overnight before retrying.
Edited by MicMac
Dear Sir - i kept the battery negative terminal removed because the battery gets drained for safety. that could be the reason for immobiliser is active. let me do the test as you instructed and confirm sir. thanks for your help and if there anything else that i need to check please help me sir. thanks in advance and have a great day.
A couple of questions:
1. Does the alarm sound if you lock the car with the key remote then open the door with the key in the door?
If you don't hear anything and the hazard lights are flashing meaning the alarm has been triggered, it could be the alarm module is faulty due to a leaking internal battery which is draining the main car battery.
2. Does the radiator fan still spin whenever the ignition is switched on?
Could be the electronics are still corrupt after the battery change rather than anything physically being wrong and further attempts to "reset" things are required.
See this post for how electronics go bad:
Edited by MicMac
thanks Mic. i will check that too but if i remove the G83 and G62 coolant sensors, the the temperature needle is coming back to center, in the cold condition howcome the needle can be in middle or in the extreme right. also the radiator fan is stopped when i remove the sensors.
will there be any connection in this? the door modules are removed including the lock barrel and central electonics for service
will that be have any impact to immobilizer to be active? if thats the case too, the engine should not crank right and starter is running that means it gets the power. what is the fuse to the HPP inside the engine comportment? can you please help and advise.
What engine do you have in your car?
Dear Sir its - 2.0_ 81 BHP _103 KW TDI CR 2010 DIESEL.
can you also suggest the fuse holder layouts if you have for this engine? all the fuses i checked in engine comportment and all ok but i yet to check the one inside the car.
do you find any reason as why the temperature needle in the cluster is going extreme end into red and comes back to center if i remove the coolant temperature sensors and the radiator fans stops running otherwise it runs as soon as i put the key in and turn it and the needle is going to red. this is happens in the very cool temperature or stands still of the engine.
thanks
If the electronics have been corrupted due to low battery voltage/changeover spikes anything is possible.  Think how often modern digital electronics/software/firmware go bad requiring a reset/reflash instead of older analogue electronics which always worked until something physical failed.  Maybe this is causing the abnormal instrument behaviour and not a physical component or wiring.
The fuses inside the car will vary depending on model and equipment.  If the car ran fine before  I would just remove and check what is already there.
Perhaps you could also check the wire continuity between the sensors and where they go to, also for shorting as they may have chaffed on something.  It is a long and awkward job and just because wires are inside a black plastic sleeve doesn't mean they can't fail, just they are hidden from view.
Sir - let me try to capture the live fuel rail pressure what is clocking while cranking the engine to see whats going on. can you please help how to do this in UDS protocol ECM? the options in VCDS are limited for these protocol ECM
thanks
Sorry I cannot help as I am unfamiliar with the diagnostic tools you mention.
Edited by MicMac
Well, it's not cheap, but you get more options in a registered copy of VCDS than in the plain download, and more again in the full paid version.
Hi Dear all i have paid version of VCDS and found the way how to measure the fuel rail pressure live. the issue is this CAR ECM us UDS and test options are very limited in VCDS.
the VCDS did not identified the fuel pump issues and intermediate operation. i need to clock the pressure contineously.
thanks
Dear Sir - i was away for while due to various medical reason, i just back and checked the complete car mechanical part, circuits etc. the car is still not starting and when i checked the compression its perfect, the fuel from the fuel tank and the electrical pump are perfect. but the fuel is not coming out from the high pressure pump. i removed the metering devices and tried to check whether the signals are comping in the metering device by cranking, the car is started that means when I remove the metering device and not connected to the HPP the car is starting. do you have any idea why is this sir? your advice will be must helpful.
hi - greetings and hope all will have a great weekend. please help me for the situation, the car is starting only if i remove the metering device from the high pressure pump and will that be the metering device fault? is there way to test these valves? please advise.
hi Sir - today i tried with VCDS and if i remove the metering device the VCDS is catching up the same and reports the N290 is open circuit. if i connect it back the error is goes away. the car starts only if i remove the meter devices connectivity and hangs off if i connect it back. if i remove it the VCDS is saying fuel high pressure and shutting the engine after some time.
so will that be a metering device issue. and i wanted to confirm before i replace it. is there a way that i can check the metering device for fault? please help.
thanks in advance.
Dear All - hope all should be having great weekends. problem statement is my car is not starting. it had flat battery and was standing for a while on flat battery. I recharged them and connected it back and the car started fine, it was running fine for 15 minutes and then stopped and from then never starts again. i checked the following
1. battery terminal voltage - 12.5 and above and good
2. compression test on cylinder - all ok as per factory manual
3. fuel from tank pressure and flow is ok
4. fuel delivery from electric pump to HPP is good and pressure is perfect as per factory manual
so i suspected the HPP and removed the delivery line of HPP that goes to injection units distribution and found no fuel coming. i though it could be HPP issue and traced all the fuses, cables relays etc both in cabin, in engine comportment, all perfect. however the HPP is not sending fuel. so i removed the N290 fuel dosing (metering device) from the HPP to check the signals, and cranked the car without the metering device connected to HPP, the car started running fine. it run for quite a while and stopped after some time saying the fuel pressure is too high in VCDS. also the vcds is reporting the N290 valve is open circuit because it was not connected. if i connect it back to HPP and the car is not at all starting, it cranks well and the VCDS is not reporting any error in the engine module. below is my scan report. is there any expert advice that i you share to check ? how do i check the metering device whether this is faulty? i do not want to buy a new one to replace them before confirming thats the issue. its very expensive here in India and please help. below is my vcds scan report.
below is the latest scan report
how do i get the freeze frame data using the VCDS?
Saturday,25,September,2021,16:49:53:29955
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Revision: 42H20--- Serial number: CVN: BA7A8368
VCID: 76B5E25848406D8B8DD-8022
VINID: 91D49279306A2514411410C710D22E088E
Readiness: 0 0 0 0 1
Revision: 00H35001
Coding: 0017665
VCID: 7BA3F36C7FE230E3F23-802E
Revision: 00005001
Coding: 0000001002
VCID: 03538B8C0B924823BA3-8056
Revision: 00103 AG
VCID: 323D1E48E42831AB615-8066
Coding: 00D7B7
Coding: 0730ED
Coding: 100001
VCID: 40D944805A84933BE71-8014
Coding: 0012343
VCID: 7DA7FD7461F63ED3CC7-8028
Coding: 0000003
VCID: 025D8E881808412BB15-8056
Coding: 110800
VCID: 38292C6002D4DBFB5F1-806C
VCID: 698FB924057EB27310F-803C
Coding: 000000
VCID: 6A8DC6280CF8B96B195-803E
Coding: 0004854
VCID: 76B5E25844C06D8B8DD-8022
1 Fault Found:
Revision: 00H17000
VCID: 313F1144ED2E0AB318F-8064
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 116447 km
Time Indication: 0
Date: 2016.02.16
Time: 02:54:01
Freeze Frame:
DD
Temperature: 38.0°C
Count: 2
Count: 0
SteerAng n.Init
Coding: 0004854
VCID: 48C95CA07EB4AB7B2F1-801C
VCID: 313F1144E12E0AB318F-8064
Coding: 0000144
VCID: 323D1E48E82831AB615-8066
Coding: 0000144
VCID: 33331B4C173238A36A3-8066
End----------(Elapsed Time: 00:57, VBatt start/end: 12.1V/12.1V)-----------
hi All good morning and hope all should be doing great. while i am waiting for some expert advise from you i continued my investigation and following is my observation. this metering device N290 is normally open solenoid valve and if you give the signal, the valve closes. so if i remove the signal connectors the valve is in open condition and allows more fuel to the rail and VCDS reports fuel high pressure and shuts the car. if i connect the supply connectors back to this valve the valve closes and no fuel to rail and car is not starting. short story short, i yet to trace the cable from the valve to the fuse holders but i checked all the fuses. all i need how will the ECM controls this valve, technically the ECM closes the valve when the fuel pressure is high and more fuel comes and so on. i think it take the input from G247 fuel pressure sensor on the distributor and also the fuel pressure regulator N276 which builds and release the pressure as needed. I checked the return fuel pip for clogging and its free. but engine module in VCDS is not reporting any error other than the coolant temperature is very high if i connect the coolant temperature sensor in the radiator outlet G83 and in the coolant inlet connects to the block G62 and because of this the temperature sensor reading in the dashboard insert is showing extreme red. I yet to check the Oil level and oil temperature sender - G266 under the engine block cover and yet to trace these cables back to fuse tray for any rat bites. is there any  other technical advise please help me. i am trying to fix this over this weekend please help. appreciate all your help in advance
  • Sponsor
N290 has a 12V feed (blue/red wire, from engine bay fuse 14) on pin 2, and pin 1 goes to engine ECU pin 60, with a blue/black wire. I imagine this connection is PWM controlled inside the ECU to vary the solenoid valve opening/closing amount. If that blue/black wire is short-circuit to chassis/engine metalwork somewhere, the valve will be 100% closed.
Similarly, a short circuit to ground/0V on the wiring to either G61 or G83 may be causing the ECU to wrongly conclude that there is a very high temperature in the cooling system.
Look for areas that wiring may have rubbed on metal parts.
thanks you sir, let me trace and update sir. thanks and have a great weekend.
