Front Hub Carrier
Just quick one
Are all hubs the same on Fabia 2?
Meaning are there any differences between one from a VRS And other models and are they interchangeable?  I need a hub as mine I bent and there are a few on eBay.
Thanks for that.
I will investigate further
Vrs and some Montes have 288mm brakes so they have different hubs. I think 256mm brakes have the carriers built into the hubs so they're not compatible.
  • Sponsor
You'll have 288mm discs, I would think, on a vRS, so you'll need  bearing carriers with part numbers 6Q0 407 255S or 6Q0 407 256S, for left and right sides respectively.
Thanks for the info 👍
