Power steering fluid.
Just a quick one only job ive not done now is change out the above, whats the correct or best to use please ???
Thanks wino :)
Will I need to do any kind of bleeding or anything after I put the new fluid in ???
No, not if you're just topping up.
I see you're changing the fluid, I have no idea why you'd bother but when you do just jack the front wheels off the ground and go from lock to lock until the squelching noises stop.
