Urgent help needed.Low oil pressure on Vrs
Hi guys.Hope that someone can help.Its second time that low oil pressure light came on.Happends on cold start.Oil is level basicly I turn car on and about 10seconds latter comes up.Turn it off then start again same thing.After turning on third time everything is ok.I dont know any VAG specialists around my area so hope on your advice.Thanks
I'd get it checked. Vw specialist or not. Rule out faulty oil pressure switch. Beyond that, clogged oil pick up or faulty pump....
Will try to get it to garage now as this morning wasnt good at all light didnt go off
Changed oil pressure swich and car runs sweet as.No more low oil pressure.Figured out that it could be sensor as there was no any rattle with warning light.Then also engine looks prestine when taking oil cup off so rulled out blocked oil pickup pipe.
Great!!
