Engine revs
Hi all
Does anyone know what the 2.0L TDI 200 DSG revs at around 70mph?
Thanks in advance!
Phil
It will be between 1500 and 1700rpm. The 7th gear on a DQ381 is really an overdrive and this drops the engine speed to very low rpm.
Thank you for that. Doesn't the 200 have the DQ500?
The 190hp TDI used to but with the new engines (190hp TSI, 200hp TDI) those moved to the DQ381. Only the Kodiaq RS TDI kept the DQ500.
