Any Kodiaq parts diagrams on-line ?
I want to order a few items for rear brakes ....
Can find sites that sell parts, but to identify the correct items really need a parts diagram/schematic .....
For example I go to   skodaparts.com    for Kodiaq it shows several bolts/screws, but without a diagram no way of telling which are the correct ones.
Anybody know a resource for parts drawings on-line?
Thanks for that ..... now I'm confused.
Videos showed Caliper held on by 2 machine screws
and Caliper fixed frame also held on by 2 machine screws
That parts list   https://tinyurl.com/yucy8rjx
shows no such fixing screws for the Caliper assembly .... refers to unit as 'floating Caliper brake'
Shows a guide pin & bush  (item 7)  ....anybody know what holds these pins into the Caliper Carrier ?   ae they screwed in ? ..... maybe end of them has a hex or torx socket
It does shows complete assembly is fitted to axle by bolts (item 8 )  but no part number listed.
Anybody worked on these brakes ?
  • Sponsor
Guide pin will screw into carrier I think. Probably a female hex inside the capped end to undo/tighten it with male hex key.
Item 8 appears to be  PN: N 91168901    M12X1,5X65
Try via here: LLLParts  not sure they're really allowed to make those catalogues visible to Joe Public, but they seem to be just now, so fill thy boots.
N 91168901
Edited by Wino
Thanks for that ... those diagrams are really useful.
Would you know where I could find Torque settings for the pins(7)   & fixing bolts (8)
Does Skoda make such information available ?    or anywhere else.
Edited by Sargan
  • Sponsor
I think you may be able to find torque info on here. You can get workshop manuals for a small fee via erWin Skoda but someone will hopefully be along shortly to offer you a free pathway to the same info.
Anybody who knows the Torque settings or where I can find them .... please let me know.
My new discs & pads arrived today  🙂  so getting all together ready for the job.
Edited by Sargan
Not to loose.
and not too tight.
Have been getting all parts together
Including the Calliper frame screws
These are M12 but have a female splined head.
12 pointed star
Anybody able to tell me what that is referred to as ? .....  so I can buy correct tool, assume I can get an appropriate 1/2" drive socket to suit ... once I know what the are called.
Think I have it right as a  'Triple Square'  .... its certainly not Torx
Edited by Sargan
  • Sponsor
XZN by the sound of it, but be aware that these are sized in a confusing way.
The 'M' number of the bit doesn't (always/necessarily/ever??) equate to the thread size 'M' number.
Borrowing an image from here: TONE 3TS Triple Square (12P) Socket | Kouei Japan Trading Co., Ltd. (koueitrading.com)
If you measure corner to corner on the head you can work out what size bit you need:
Edited by Wino
Great I had measured it right as M12  Triple Square XZN
