Huge metalic grinding noise
Hello,
I hae a problem with my Skoda Superb 2012 and by having a problem I mean there is a huge metalic grinding sound coming from engine/differential. It is so loud I fearof differential locking up entirely during my long trips. The sound comes at random, there is no specific action done with the car. No matter the speed 50 or 140 km/h it may come on for about 2-6 seconds (some times up to 15-20 seconds) and go away. I tried putting the DSG gearbox into neutral immediatelly after hearing the sound but had no difference in the speed of the sound even thoug acceleration of the car is non existing (causu of neutral position), I tried breaking emedialely allmost to a stop and that too does not make a differance. All i can feel is some vibration on my pedals and that horrible sound. The car has driven 300k km and even after the needed flywheel replacement the sound is still there. I have researched this topoc of grinding sounds and no there is no stone in my brakes or something simple as that. Would help a lot if there is someone with any clue what is happening. Thanks
Try turning the a/c on and off when the noise comes.
To turn off the whole system or the AC part of it ?
Just press the air conditioning  (AC) button . that will stop the load on the compressor and may also stop the noise. turning on again will bring the noise back if i am right.
Thank you for the idea. Wil try to turn the the system completely OFF because i did not use the AC part of it as the sound was coming and going. But seems interesting. I will update if something happens.
Thank you!
