Intake hose. Pointless?
6 hours ago, mao said:
is it pointless powerwise?
Yes, unless it genuinely feeds the engine cold air.
I have one fitted to mine, it does increase airflow marginally, although you'd probably not notice. Ignore the comments about "heat soak" and cool air, our cars are fitted with intercoolers. I have found that you may need to upgrade your diverter valve with one from GFB as a remapped car with an intake will likely cause the standard one to fail. I also had to replace my intake manifold as the vacuum "valve" in that was killed by the extra airflow.
