Replacement factory fitted USB port?
In pulling out the cable connecting my phone to the factory fitted USB port (connecting to Apple air play), I’ve managed to break the little white connector inside the USB port. Does anyone know whether the port can be replaced?
Thanks.
it should be able to be. You'd just need to find said part number (the site I use is working at the mo)
IIRC it's something which plugs in the back of the screen, so swapping it would require having it removed temporarily
This should be the p/no which you can Google  5Q0035726E
Thanks guys, I’ll get onto it.
