Fabia with no spark
Hi any ideas my fabia is just turning over with no spark it ran crap missing and now won't start
What engine do you have? Can you tell us the engine code please? :)
That's perfectly normal for a diesel. And if you have a petrol engine you either get the fault codes read or start throwing money at it.
Coil pack issues are the most likely culprit, change the spark plugs while you're at it.
Are the coil packs separate to each plug as its not even firing am I right in saying if one fails it will run on two cylinders or will it not run at all
It won't start on two out of three cylinders.
More worryingly though the timing might have slipped if it's a 1.2 3 cylinder.
How you determined that there's no spark?
