engine ecu appears to be cutting down str
tdi 110  mk1 octy    does anyone know    what max str   this car should see  is it like 50  as i am only seeing  40
ecu appears to be   cutting down str   ir it reaches  40   then cuts down to 30  odd    we think that something is triggering   ecu into doing this
air intake temp    we are seeing  30-40   seems way to high on a 5c day
also  it seems to be over boosting  by about 300 -400 mb   going up to around  16-18psi on  boost guage
tia
If you're using VCDS ? hover the mouse pointer over the measuring block and it will give you a high & low range figures
hi ive got a boost guage and i am seeing  20psi    which i thnk is to much  might explore lengening actuator rod    to reduce boost  .
More likely to be the vanes sticking, needing the "Mr Muscle" cleaning trick, it stopped my old ASV Mk1 from overboosting and dropping into limp mode, I certainly wouldn't be adjusting the operating rod unless you have previously adjusted it ?
