Bluetooth not working
Hi all. Hoping to get some advice.
I have columbus unit in my superb. Car is 2011 and has multi function steering wheel and module under the seat. Module part numer is
5n0035730d.
Looks like module is dead because car does not comunicate with it and i dont even see option to use bluetooth in the radio when i press media button.
I am right that this car should have Dab radio too?
Do i need to find unit with same part number or can i fit one with same connectors? I have one big connector and also one for anthena o mine.
Tnank you.
Sorry to forum moderators,but somehow created 2 topics.
The bluetooth settings are in the maxidot (the display between the rev counter and speedo') not on columbus and are accessed using the sterring wheel buttons on the right.
There is a very recent thread with a diagram of what each button does.
Hi. Thanks for reply. I am going to have a look.
On 17/12/2021 at 09:01, superbdreams said:
Hi. When i open this menu it does not come up with option saying Phone.
Not sure where to dig now.
I thought that columbus unit must have BT audio streaming and phone.
If you haven't already, then try unplugging the bluetooth module under the seat and plugging it back in again. This usually fixes intermittent problems with the module not communicating with the Columbus. If that doesn't resolves the problem, you really need to get a scan done with VCDS or similar to see if there are error codes stored for the module. It could be that the unit is dead, but without swapping in a known-to-be-working module to test, it's hard to say for certain.
