VCDS/OBD11 : AUDI engine coding on 1.5TSI Octavia III
Hello everybody.
Has anyone made the so called "Audi mod" or "Throttle mod" by coding the ENGINE ECU, byte 0 (Hersteller data) to Audi ?
I read some topics that some had done this but had troubles with the Cruize Control.
I also have the Cruize Control not working. Also get an error in the ABS module that the coding of Engine ECU is not correct:
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 EG    HW: 5Q0 614 517 BQ
   Component: ESC           H82 0107
   Revision: 00000000    Serial number: 61429000000731
   Coding: 24076A91202321724078060160C7242456048402600624722023F070D0024B0B0000000012121212B835351919323200
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 7AFB47EFFDDF505B8D-802E
1 Fault Found:
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 77
                    Mileage: 29526 km
                    Date: 2021.12.19
                    Time: 10:12:24
I tried the Audi throttle coding on my 1.4 TSI Octavia III and had exactly the same fault codes, to me it seemed that the changed ECU coding made it look for different CAN messages from the other modules such as ABS so I reverted back to the standard coding.
I wouldn't bother with the Audi coding mod. You can code the throttle to change it from incremental to direct. That gives you the sports mode throttle in all profiles if you have the profile button. If not it just changes it to sports throttle.
I've done it.
I mean the ECU #44 mod.
  • 1 year later...
up.
