Problem with rpm on dashboard on Octavia A5 1.8 tsi
Hello everyone,
I have problem with rpm on my dashboard on my Octavia.
After 30-45 minutes drive, I have this problem.
Engine work fine.
I record my problem, and upload on youtube.
Does anyone know what the problem is?
What exactly is the ‘problem’ that you have - the soft limiter?
@john999boy
The needle appears to retard in jerks instead of smoothly.
@djuka006
I suspect needle transducer is binding somehow (check needle/lubricate) or there is a bad solder joint (resolder), only investigative disassembly will find the cause.
Edited by MicMac
