Wooden Dash insert required (3T1858418B 3T1858418C 5481579)
Hi All, I had an air freshener leak on to my large center piece wooden effect dash insert in the front of my Superb mk2 which first discolored then snapped(!) the part. I've looked all over for a replacement and found one from a company in Italy for 20 euro which turned out to be left hand drive and doesn't fit. I was hoping someone here may know of somewhere to sell me the right hand version for a reasonable sum?
Here are the part numbers:
Any help much appreciated to restore my beloved Jeeves to his former glory!
those first two part numbers relate to the LHD version, the part number you need will be on the reverse of the trim if you can get it off?
If not I expect someone will post it soon enough, I dont recal the system to convert part numbers from lhd to rhd right now.
That makes sense, thank you, I'll see if I can pries off the old one and report back.
At a guess, it'll start 3T2 for the RHD version :)
Not sure where will be best to buy them though I'm afraid. Maybe a breaker on eBay selling a similar car?
Good shout on the part number, thank you langers2k. The only one I can find is just shy of £90 on ebay which seems like a lot of money for a plastic veneer!
