Xenon bulbs?
55 minutes ago, DieselMonte said:
I've driven a few caddys and golfs that had the blue gauge lights VW used to use. Headache inducing.
Green or orange are the best for gauges/ stuff in the car.
Agreed on the headache inducing thing. I used to be able to drop the facia of the alpine (one of those drop down ones to insert a CD) and it would stop the painful lighting.
I've driven a Toyota Auris with the orange lighting and it was quite nice. The green is nice too, just wish I could do something about the glare from the high beam on my Fabia. :)
Edited by AnnoyingPentium
On 16/01/2022 at 16:36, AnnoyingPentium said:
Or for a lot less
https://www.energizedcustoms.co.uk/vehicle-lighting/headlights.html?vehicle_make=58&vehicle_model=297&year=1583
post free and very quick delivery. They are based in Telford, but will allow collection by  appointment. Approx £80 a side or £150 for a pair.
My tip for fitting the bottow radiator side bolt is to screw the plastic ferrule fully out and tie a bit of string etc to the bolt. Stops the bolt falling into the undertray when ( not if) it works loose when fitting it into the hole.
on one side I had to "persuade" the wing to move up about 1/2 inch. Possibly as it had been changed( some one with a van clobbered me).
Edited by VWD
more fitting info
34 minutes ago, AnnoyingPentium said:
just wish I could do something about the clear from the high beam on my Fabia. :)
Could always join the darkside and put a cheap pair of led spots in for high beams :D
I meant glare and will edit my post accordingly rather, didn't notice the mistake the first time round - this mobile phone malarkey is a pain. I find that the little blue telltale on the dash is a lot brighter than the rest of the lighting.
Well, I remember back in the day the first mod most people made to a Ford was to cover at least half, sometimes 3/4, of the main beam light on the dash with insulating tape.
I can understand why. I find the blue light glares across the lenses of my glasses (I didn't spring for anti-glare when I got them) so it's a wee bit irritating. I'm due an eye test sometime in the month (or the next) so will probably need new glasses then. :)
I've joined the bright side and have LED on my dipped beams. For a few years, I've noticed that the Bavarian brigade can't see a Fabia unless it's got dipped beams on. But the connectors are4 not that good, and I've changed both a couple of times. ( the cable/connectors are not up to speed for 6A ). So I now get 55w out of LED at a tenth of the current, and for those of you that don't know the formula, it's all to do with heat generated by I*I*R. At last MOT, the tester could not find fault with the beam pattern or light output. All he had to say was that the "manual" did not allow LED lamps. So I
Just now, VWD said:
I've joined the bright side and have LED on my dipped beams. For a few years, I've noticed that the Bavarian brigade can't see a Fabia unless it's got dipped beams on. But the connectors are4 not that good, and I've changed both a couple of times. ( the cable/connectors are not up to speed for 6A ). So I now get 55w out of LED at a tenth of the current, and for those of you that don't know the formula, it's all to do with heat generated by I*I*R. At last MOT, the tester could not find fault with the beam pattern or light output. All he had to say was that the "manual" did not allow LED lamps. So I now do what the "CAT" REBELS DO . I fir Halogen to keep him happy and afterwards replace them with LED.
But AnnoyingPentium is on about glare from the blue main beam light on the dash, not the headlights.
AH - mis read that apologies. Possibly as I never get the chance these days to get out and use main beam.
