Trip Resseting Help
hi everyone. i bought a new octavia mk3 2018 model SE L.
 i see there is main mileage which is 26k something also on the right hand side i see the trip 260mile. how can i reset this trip to 0 guys? because i want to observe and keep a record how many mileage i am doing in a week. can someone help me with that please.
Welcome!
From the owners manual:
thanks for your kind reply. i have checked in instrument cluster setting. there is only since and long term reset available not trip. i would like to try second method which is holding A button.
Hi, I just use button A to reset, just one press, not hold.
Which it what it says in the manual
yes thank you everyone. found the button. when i am on driving sit its hard to see the button actually but thanks to langers and naz.
Welcome to our helpful community, as you can see no question gets ignored no matter how "obvious" to others.
A very good point that those odometer buttons can be obscured depending on steering wheel and drivers position.
to add a little more for you, when you fill up with fuel, the main trip computer (found using either the main screen or the thumb wheels on the steering wheel) will reset some items such as distance since refuel, distance range, average mpg average speed etc.
It does also record distance since you first started driving, however unlike the button A you used to reset the mileage counter behind the steering wheel, it restarts that distance record if you stop for about two hours or more.
I have to record mileage for work travel and use the "button A " menu so it records my full day despite long stops.
Regards.
