100PD boost remapped and standard??
I have an Ibiza but I think there are more 100PD fabias that have been remapped on Briskoda than SeatCupra.net!
Could anyone tell me how much a standard fabia 100PD has boost wise?
Also if you have had your car remapped and know how much boost it has now?, and which map you run ie Revo, Jabba, CC etc....?
Thanks very much for your help
Kyle
standard? around 1.1 bar as a guess? remapped I suspect closer to 1.4 bar.
With a Jabba map I had a pd100 putting out a variety of power. 3 maps saw me with 147, 154 and 151bhp. :)
The 147 one was with the rest of the car pretty mucn standard.
With a Jabba map I had a pd100 putting out a variety of power. 3 maps saw me with 147' date=' 154 and 151bhp. :)
The 147 one was with the rest of the car pretty mucn standard.[/quote']
Was hoping you would answer! lol
Mines been mapped but vagcom only suggests 1.25 bar!
Whats more acturate vagcom or a boost gauge?
well,in theory both should be the same, but a gauge should be ultra accurate if its calibrated right
also from my rolling road result of 135bhp and 200lb/ft also suggests that boost is about right ie 1.2?
but then again standard 130's run about 1.35 bar!
1.2 is about right then. I expect the fuelling is a little higher on your pd100 - more fuelling, less boost. Its one way of being remapped I guess, For the mid 140s I suspect you need boost setting around 1.4 bar.
interesting......
I have asked the questions so Ill post back any info once I get a response!
Thanks mate for the reply!
How long did you run 1.4 bar at? do you think 1.4 is safe or right on the edge??
1.4 is ok for the standard pd100 turbo I think. Remapped PD130s generally are around 1.6 bar.
I think mine at the moment is kicking about 1.3 and doing 150bhp.....
