Service Schedule for 2014 DSG 4x4
darfash01
I go by this - but you need to look at both service and maintenance (scroll down the page).
ŠKODA Servicing & Maintenance | ŠKODA UK (skoda.co.uk)
In brief re maintenance
Brake fluid - every 2 years
Haldex oil - every 3 years or 30k miles
DSG oil - every 4 years or 40k miles
Cambelt/waterpump - every 5 years or 50k miles
You may also want to add an aircon service - opinions vary about the necessity of this.  Probably less necessary if you leave your aircon on more-or-less permanently, but if it doesn't blow cold, then it's likely the refrigerant has leaked.
Aircon system cleanse you can easily do yourself if you get musty smells - no technical skills needed. Just buy and use a can of cleanser.
Regarding the Haldex, be mindful that Skoda dealers do not change the filter, which clogs causing Haldex failure - I use an independent. There are threads about this if you search.
