Window Frame Corrosion
Can you get replacement divides for the rear window? It looks the rubber could be one piece for the whole door.
Anybody came across a solution for this before?
See pics
Come the warmer weather, unless you have a heated garage, you could perhaps try straightening out the rubber strip by applying reasonable heat and clamping, perhaps to some planed  wood.
