Full-size spare instead of inflation kit
Hi I have only found the rim size online for a 18inch vrs alloy, not the PCD etc
I'm wondering if a 2011 shares the same wheel well with other VAG cars?
My main dislike is space savers and 50mph-any advice on a alloy or steel rim, factory jack correct wheel polystyrene wheel liner and clamp.
Also is ebay the way forward or somewhere cheaper?
Located Somerset
If you have a standard VAG wheel, the full side specification will be cast or stamped into the wheel.
As you can see in the chart below, the Octavia MK2 came with either 6Jx15 ET47 or 6.5Jx16 ET50 steel rims.
The 6Jx15 ET47 uses 195/65R15 tyres, and the 6.5Jx16 ET50 uses 205/55R16 tyres.
Octavia MK2 Steel Rims
1 1K0601027K steel rim 6.5Jx16 ET50
  1K0601027K 03C black 5/112 57.1
3 1K0601027C steel rim 6JX15 ET47
  1K0601027C 03C black 5/112 57.1
https://skoda.7zap.com/en/cz/octavia/oct/2011-663/6/601-601010/
Alcar 9165 6Jx15 ET47 5/112 57.1 Steel Rim
https://www.mytyres.co.uk/rims/details?vehicleId=183006013861926000&rimCode=ALCAR9165
ALCAR 9165
Alcar 9915 6.5Jx16 ET50 5/112 57.1 Steel Rim
https://www.mytyres.co.uk/rims/details?vehicleId=183006013861926000&rimCode=ALCAR9915
ALCAR 9915
Edited by Carlston
Thank you for help, local breakers may have something and said they will look and call me back
Local breakers a run flat and tool kit etc-£10 🙂my lucky day while hunting for a full size Spare
That's not a comprehensive list, is it? My Mk2 Octy has 17" Pallas alloys.
17" alloys aren't steel, and the OP is looking for a full-size spare wheel.
"the Octavia MK2 came with either 6Jx15 ET47 or 6.5Jx16 ET50 steel rims."
All the Skoda Octavia MK2 alloy rims can be found on 7zap
https://skoda.7zap.com/en/cz/octavia/oct/2012-663/6/
Edited by Carlston
I'm wondering if a golf or similar 16 inch steel rim and tyre rolling radius similar to Stock 18 alloys and tyres?
Thanks for replies 🙂
Same outside diameter
195/65R15
205/55R16
225/45R17
225/40R18
The above tyre sizes are interchangeable as they all have almost the same outside diameter.
Exactly my point, It's not a comprehensive list. What you meant, but did not write, was "the Octavia Mk2 if fitted with steel wheels came with either 6Jx15 ET47 or 6.5Jx16 ET50 rims.
