Fix front windscreen spray nozzles?
Have non heated spray nozzles, is there any way to adjust them? Thanks.
Yeah, they can be adjusted.
Should be a small torx, flathead or Philips next to the fan outlet
Thanks, have put my manual "somewhere safe".
Well, mine decided to stop spraying strong (no pun intended), can they be removed wtih the same procedure, as i would like to clean them, probably clogged, or limestone accumulated, i also have the non heated ones!
youll struggle to clean them, you can try taking them off and using vineger and a high pressure air line, but fan jets once blocked are hard to unblock
Well, since i have some spare free time, ill at least give it a try before resorting to the main stealer.. Also, cant seem to find the topic again, was there not an upgrade to those, like from a passat, or similar? That gives better spray pattern?
And i dont think mine are the fan jet type, rather gives out 3 or 4 streaks of liquid, or it might be they are both so clogged that it seems as streaks rather then fan jet type spray..
