Please help. Need advise.
Hi guys. Hope you all doing good. I did have another account but I couldn't retrieve password.
The other day I came out started my 2.0 2008 vrs octavia Estate and I had no power steering. I turned wheels full lock both ways and got my power steering back but it's left me with tps light and traction control light on with following fault codes related as showing
01435 Brake Pressure Sensor 1 (G201)
00778 Steering Angle Sensor (G85)
01423 Lateral Acceleration Sensor (G200)
Is it possible all 3 sensors need replacing or is it likely to be one over the other. Just looking if anyone has had simalar fault.
Thx in advance 👍
I would suggest it's a wiring/connector issue.
Have you deleted the codes to see if they appear again?
Also any further information on the codes would be beneficial, usually it will state 'defective, Implausible Signal, Incorrect Adaption'.
