Glow Plug Control Module
Does anyone know where I can find the glow plug control module?
I have an amber engine management light on. A test shows that fault but I don’t know where to locate it?
it’s a 68 plate Kodiaq. 0DACC2AB-191B-4885-A236-86669C18923C.thumb.jpeg.2aacace66e226f09f0e5f02e0279ee15.jpeg
Glow plug timer relay. It's in the fusebox under the bonnet. I think wiring could also cause this fault code, but replacing the relay would be a good first start. Do you get any kind of used warranty with the car? It would be an easy dealer fix if so.
Edit: sorry, I confused you with another user - I don't know if you bought your car used or not.
Edited by Teir
No I don’t have extended warranty on it.
I’ll try and take it out, replace and see what happens.
