Spare wheel for 2017 Superb estate
Hello everyone, I hope you're keeping well, I have a question about spare for my 2017 Superb estate, Q: Will a wheel and foam insert from a 2011 Superb fit in the spare space of my 2017 Superb and allow the boot carpet to be flat?
Maybe a silly question, but I've found one that's an hours drive away at least and don't want to buy it or travel that way unless I know it will fit.
Thanks in advance for your help.
Kind regards
What size is this 2011 Superb wheel?
If it's a 205/55/16, it's the same same as the Mk3 spare wheel., Id it's a 225/45/17 or a 225/40/18, forget it, it wil lift up the boot floor a bit...
Another point to check is the ET value, to be sure it won't hit the brake calipers.
Hi there, thanks for your reply, it's a 2055516 tyre
The rim size may be different though, different offsets or pcd, may not be the correct fitment
I had a 2011 60 plate Superb 2 (18's) Elegance with a spare small wheel. My 67 plate SE L Executive (18's) only came with the glue and pump.
I swapped my old spare into the new one, including old foam insert.
Fits perfectly, floor still fits flat.
Don't forget to remove the the plastic base from the floor... Push down and twist to remove.
Great stuff, thanks for your help.
Thanks all for your help, it's much appreciated.
