Throttle pedal issue ?
Hi Guys :)
i have a strange issue
sometimes when for example i stopped at red light noticed the rev is stuck arround 1100-1200rpm but if i pull the pedal up with my feet rev jump back to850 , also sometimes noticed car isnt pull smooth but if i pull back the pedal again pulls again normal for a while
what the actual f**k ? PEDAL or  position sensor or or ....   what ?
Thank You
car is.  1.9. BLT
Throttle pedal position sensor. That's the same issue mine had.
Hope this helps. :)
Thank You! :)
soo. than I need a new throttle pedal?!!
You do. It's one whole unit, as seen below with an image from the world wide web outside of here. Mine came from a car that was being broken for spares. I can't remember if the part number is different for the BLT, so others may be able to advise.
Hope this helps. :)
Hope this helps. :)
Thanks very much :)
