Very slight oil leak from oil filler cap
Hi All,
Ā
I have owned a 2014 220 TSI for about 1.5 years and when buying I noticed some oil around the filler but assumed this was someone doing a poor job of filling it up at one point. However even after cleaning a very light almost oil residue reappears. I can't see it coming from anywhere other than the filler cap. I have attached a photo of the cap and oil residue. I have checked with Skoda and a replacement cap is £13. Am I missing a seal or have a faulty cap? Has anyone else had this problem and a new cap cured it?
Ā
Thanks and apologies if this has been asked before I have searched and not found a resolution.
Ā
All EA888 engines seem to do that.
Let me correct you slightly - VW/Audi engines in general seem to do that. šŸ˜‚
Ā
Especially if you ā€œtrashā€ them from time to time :)
Ā
I had several VW petrol and diesels, and all of them were leaking a bit from there. I had an Audi A4 B7 1.9 TDI which even had additional rubber around the cap, which I’m 100% sure was designed because VW didn’t want oil all over the engine.
Thanks for the replies. Guess I won't bother with the new cap then šŸ™‚
